Range Rover Sport
				Well I got back from Oulton Park yesterday, engine bay up just to check fluids and on a closer inspection there seems to be a lot of oil around the highlighted section.
The thing that really confuses me, its really thick oil. In fact its more like grease than oil. However after a quick look under the car there seems to be 2 oil lines running under the engine/sump. Again this is extremely dark oil ( Black ).
When I check the engine oil, it looks fresh and as it should not the type of colour it is in the highlighted section / under car?
( *Not my car or engine but an example )
1) Could it be oil that has gathered there over time and due to the 'track' driving heated up to an extreme it indeed got thinner and ran down the engine under the car? ( Here is me hoping )
2) Sump needing to be resealed? ( Not sure the oil would be where it is if it was the sump, would explain under the car though ).
3) Oil filter has a small leak? ( Again this wouldn't explain around the sensor though )
4) Dip tube leaking? ( As above not sure it'd explain around the senor )
The oil seemed to gather in between the oil filter and oil dip tube around and under the sensor.
Any suggestions would be great!
