I need a little advice..
S7u
Car  Clio mk3
I own an mk3 non sport, and I'm having it lowered next friday on springs.
I also want to get a new set of alloys, and i quite like the megane nervasports 17"
My question is, will there be a problem fitting these after being lowered and are they the same fitment?
thanks!
The Nervasports Jesus had on his mk2 were 4 stud so you would think they are available in 4 stud....Offset wise I don't have a clue mate but they should fit your Clio mate
Worse case scenario you may need spacers to prevent rubbing, and 17's look fine on the mk3's IMO mate
Nervasports are 4 stud defo cos i had them on my 2.0 meagane only the rrenaultsports are 5 stud and maybe the diesels
There's a lot of dreadful advice floating around on this forum of late... :(
17 inch Nervasports will bolt straight on and cause no issues at all. You may want to look at some spacers as once the car is lowered, they will look a little sunken.
JP on here has them on his dci 86 and it looks superb. I'll see if I can find a link...
thanks!
Here you go.
(It wasn't difficult. I typed 'Nervasports' into the search bar and this was 3rd on the list...)
http://www.cliosport.net/forum/showthread.php?690762-JP-s-Mk3-Dci-86&highlight=nervasports
