I suppose you have to buy to try not good though but I have never of a kranzle ,is that german or what?
Yep.
TBH I’d never heard of them until I started looking into washers etc.
£199 from tool station 👀 <-----IGNOREJust got a Karcher K7 Compact in a Black Friday deal for £260. Absolute bargain.
Scratch that... I searched for K7 and it then shows you a K5£199 from tool station 👀
I think that is going to be the problem as it could be a bigger issue with the water supply/pipes that is out of my control. Hmm will have a rethink. If i can't get the water pressure sorted I will not bother getting one until I move as I can see it happening again.To be honest, I would be trying to sort out the water pressure situation before buying a PW. I say this because I've never come across a PW that is gonna handle a sudden drop of pressure and as you know, this can kill them. I'm sure this is why so many Kartchers go bang. Always drain the pressure out of them once you're done using them and never run them dry. That said, there is a solution. A swirl pot if you will.
My one, Direct Hoses All Black 7 (or 9 I don't remember) can run from a bucket. So, in theory, you could buy a massive 25L drum, fill it up with the tap and then run your PW from that. As long as you keep an eye on the level, its never gonna run dry. Gotta be worth a shot! Good luck
I've got the worx hydro shot, it's decent enough, cleaned the patio at the front well enoughI’m after a pressure washer. But can’t get power or water to it.
Doesn’t need to be massively powerful. Mainly for blasting pigeon s**t/pigeons off my balconies but also to wash my windows and of course to generally wash the car (which is where the lack of water/power issue really comes from).
There’s a few options, main ones I think are the Bosch Fontus which is pretty hefty but has a good sized tank but weirdly uses a tiny 2.5ah 18v battery, the Karcher OC3 which I think probably isn’t going to cut it but is a lot smaller, or something like a Worx Hydroshot and a bucket, but I don’t think they’re as powerful.
Anyone got any ideas or experience?
Cool. Do you just run it out of a bucket or off a hose?
Standard CS, I’ve just bought a Bosch Fontus instead. Looking at videos it should be enough for my needs, should make my life significantly easier.
Price here was actually pretty decent, cheaper than elsewhere definitely.
Bosch FONTUS Gen II P4A 18v Cordless Low Pressure Washer 20 Bar | Pressure Washers
Buy Bosch FONTUS Gen II P4A 18v Cordless Low Pressure Washer 20 Bar and other Bosch Home and Garden Pressure Washers at Tooled-Up.com. Fast Delivery.www.tooled-up.com
The god tier combination of crocs and socks? Don't hate me cause you ain't me
Honestly that balcony was minging, I wasn't going to walk on it until I'd cleaned it with anything less.
