Pressure washer recommendations?
P-Co
  Hyundai Santa Fe
DrR
  VW Golf GTD
Any recommendations for about £100. Won’t get used that often, just for cleaning van/car once a month.
KitsonRis
I need to get a new pressure washer as mine died the other day.
It was a gift last year and was a MucOff motorbike one, although it did come with three lance attachements with varying degress of nozzle pressure. One for a car, another for a motorbike and another low pressure for bicycle. Tbh it was pretty good for a bike cleaner due to the lower pressure lances but still beefy enough to clean a driveway (ish).
But the issue I have is that got a tap installed in my garage, it is spured off the main water inlet for my flat (coach house above the garage) and is about 6" away from the main stopcock (this is the only place it can go as the mains water pipe is exposed for about 2' from the groud before it dissapears into a cavity in the wall). But for some reason the water pressure coming out of the outside tap can be a bit tempermental and drops. You could hear the pressure washer struggling at times and spin the motor with no water coming through, I always turned if off when it did this as I know that it would kill it. Water pressure in the house is fine though and I am not running the washing machine or dishwasher to take water pressure from the tap. And the other day it died.
Anyway....I need a new pressure washer. Are there some that can handle this kind of water supply pressure variations better than others? Basically want a like a swirl pot for it
Not heard of the brands that have been mentioned in this thread. And I love the set up @Sidnancy has! If I was in a more permanent home/garage I would look at doing something similar.
Turd Pocket
  Cumpact
To be honest, I would be trying to sort out the water pressure situation before buying a PW. I say this because I've never come across a PW that is gonna handle a sudden drop of pressure and as you know, this can kill them. I'm sure this is why so many Kartchers go bang. Always drain the pressure out of them once you're done using them and never run them dry ;). That said, there is a solution. A swirl pot if you will.
My one, Direct Hoses All Black 7 (or 9 I don't remember) can run from a bucket. So, in theory, you could buy a massive 25L drum, fill it up with the tap and then run your PW from that. As long as you keep an eye on the level, its never gonna run dry. Gotta be worth a shot! Good luck
DrR
  VW Golf GTD
I bought this in the end, in typical CS style I ignored all the advice given.
was £120 on offer. Not used it jet but feels good quality.
KitsonRis
I think that is going to be the problem as it could be a bigger issue with the water supply/pipes that is out of my control. Hmm will have a rethink. If i can't get the water pressure sorted I will not bother getting one until I move as I can see it happening again.
It was always drained, mainly as I have carpet in my garage and didn't want it to get wet! Also don't have room for a 25L drum but that would be a good solution really.
But have just been looking at the Nolfisk ones, seem good value!
It’s not glamorous and won’t earn any cred with the neighbours or on internet forums, but you won’t find better value than one of these:
Yes they do break but buy the the extended warranty for £21 and you have a decent tool for at least three years for £76. They use a Lavor fitting so are compatible with various attachments.
McGherkin
McPension
I’m after a pressure washer. But can’t get power or water to it.
Doesn’t need to be massively powerful. Mainly for blasting pigeon s**t/pigeons off my balconies but also to wash my windows and of course to generally wash the car (which is where the lack of water/power issue really comes from).
There’s a few options, main ones I think are the Bosch Fontus which is pretty hefty but has a good sized tank but weirdly uses a tiny 2.5ah 18v battery, the Karcher OC3 which I think probably isn’t going to cut it but is a lot smaller, or something like a Worx Hydroshot and a bucket, but I don’t think they’re as powerful.
Anyone got any ideas or experience?
MatthewR
I've got the worx hydro shot, it's decent enough, cleaned the patio at the front well enough
MatthewR
Cool. Do you just run it out of a bucket or off a hose?
I've used it with both, and there isn't a difference in pressure whichever feed method you use.
The 2amp battery doesn't last that long but at the time I bought the jetwash I also had some other worx tools and therefore batteries so it wasn't an issue.
You can definitely get one full car wash out of it or a medium sized patio if fully charged
McGherkin
McPension
Standard CS, I’ve just bought a Bosch Fontus instead. Looking at videos it should be enough for my needs, should make my life significantly easier.
Price here was actually pretty decent, cheaper than elsewhere definitely.
davo172
  TCR'd 172
Sounds like a disease 🤣
McGherkin
McPension
She chooches quite nicely actually. Obviously not as powerful as a proper power washer but plenty enough power for what I need. One tank did half my balcony and it’s still on 3 bars of battery so that’s a win.
McGherkin
McPension
First proper car clean with it.
Used about 4 tanks if I remember right, had another probably 3/4 of a tank left in the hog at the end too, and I really wasn’t trying to conserve water (like f**k was I going to carry it back with me), but a tank would do one rinse I reckon. Only used 2/3rds battery.
it absolutely RIPPED through the detergent bottle, not sure if that’s right but it did make reasonably good foam. Might have to test the draw through ratio because I’m not sure I believe the quoted 3 to 1.
I’m really quite impressed, I think it’s still early days for battery powered pressure washers but it’s already good enough to do a car with and that means I can give my car a proper wash at home for the first time in forever.
McGherkin
McPension
The god tier combination of crocs and socks? Don't hate me cause you ain't me
Honestly that balcony was minging, I wasn't going to walk on it until I'd cleaned it with anything less.
McGherkin
McPension
Ol’ faithful out for another rip. It’s actually really good.
I’ve got down to using a bit under two tanks but that was with iron-x ing the wheels and being a bit wasteful.
Martin_172
My mate has a kranzl and it's a cracking bit of kit, I love how quiet it is, I keep saying I'll get one when my K4 dies but so far it's about 9 years old and is still going like it's brand new, key is strong water pressure and empty it when done. I leave mine setup in the garage with a 15m hose drilled thru the wall that reaches up to the street and round the cars
Clio_fool
Just bought an Ava since my child adopted my K4. I settled on the 'easy' model because it comes with a 12m hose. The whole ava line up is massively confusing though, they have far too many machines and accessorie packages to scrutinise. Won't be testing it until next weekend though unfortunately.
Matt Cup
  Iceberg 172 Cup
Replaced the 6m hose on my k4 for a 15m. What a revelation, makes a huge difference now I’m not having to lug the unit round the car when I need to change sides.
Cookson
  Mk1 Audi TT 3.2 V6
Is the hose fairly flexible? Mine is quite stiff and tends to t**t the car whenever I turn around
Matt Cup
  Iceberg 172 Cup
Yep pretty flexible, it’s still new so need to straighten it out a bit as it gets a bit tangled. Was only £15 so can’t complain tbh.
  BMW 330ci
How are you getting on with this? My old Nilfisk has died so need a new one. Would love a Kranzle but way over my budget. So like the look of these plus the 10 year warrenty. Will be used for car cleaning and pressure washing the slabs. Any other alternatives.
Matt Cup
  Iceberg 172 Cup
From the detailing thread,
Clio_fool
It's been fine, no issues at all and we're in a hard as f**k water area.
ex-Chinese Dave
  172 Cup
One the subject of cordless pressure washers…
I may be buying an apartment that comes with a garage, but it has no water or elastictrickery. I would probably need a battery drill too for a bit of DIY, so I should buy the same brand. Has anyone used those Worx pressure washers and drills, and if so what do you think of them?
