Pearl Black 172 PH1
Gus
  182Turbo,DCi90
Always great when you update your thread. Absolutely stunning car btw.
Id never heard of a renault option for the Oz ultras either. Such a nice designed wheel and so light too. Bet they were expensive.
  01RS,03 EP3,99 Evo 6
Also - were they a straight fit, without needing spigott rings like the usual oz ultras?
Thank you so much for the kind words :giggle:🫠
Yes, bang on ! Don´t need spigott rings like the usual ultras! It´s a big plus in my opinion!
PerthRS
  Clio 182 CUP
Wow that is the first I have heard of OZ ultras being an option as well!
Wasn't an option in Australia with the 85 phase 1's we got. As far as I know.
And time for another update.
Noticed for a couple of month a slight coolant smell sometimes, but nothing in the floor of the garage, nothing on the engine oil, but i could smell it from time to time, but could not find the leak . Put the coolant system on pressure, and nothing. No pressure drop. Could not figure it out .
Since i had some free time, decided to remove the interior, and look what i found...
There it is my coolant leak. The heater core said enough is enough after 23 years. Since i had the colossal work of removing all the interior and dash, decide to perform some modifications that were in the back of my mind for several months (more on that later).
War zone
And parts everywhere!
In the meantime, one thing that was starting to want some attention was the rear exhaust bush. Decided to give the Grams sold by Kamracing a go.
The kind guys at DHL charged 15€ for present it to the customs (a process witch i do myself in any order from the uk, but when it´s shipped trought DHL i have no other choice than pay it). After the customs taxes added this mount came in a total of 80€!!! :mad:
Installing it was piece of cake
The original was showing some wear but not as bad as some i have seen over here
And the new one in place
Great product. No increase in NHV.
In the meantime took the car to a small track that we have around here , about 1200 M. Small but very cool to drive on it . Went with some friend just to have some fun.
When arriving there started to rain. It´s almost impossible to have rain in Portugal in August, but here we are :LOL:
On the way to Bombarral
Some friends cars
Ready to start
The Clio performed really well. The track was really greasy, used the Nankang NS2R with 2.2 cold front, 2.2 cold rear. After 5/6 laps they started to overheat, went to the pits and the fronts were 2.8 and rears 2.3. Aired down the fronts to 2.2 hot, and the rear to 2.2 hot and kept lapping all afternoon.
In the end the Clio done about 50/55 laps. That is about 60 Km of track. Not much, but always fun.
Here is a small video from outside when you can hear the Clio chasing a good friend of mine in his 2.0 ND.
KevC
  Clio 172 PH1
I missed your update about the interior when you posted it. Is there any negatives or drawabacks to removing the seat spacer? Being 6ft, I would welcome the seat being a little lower and now is the time to do it with all of my interior taken out.
@Filipe Dias Make sure you cable tie your Grams mount to the metal, mine fell out so had to cable tie it in on each side. <ine has been fine since.
Wow, didn´t know that! Will follow your advise. Thank you so much (y)
Imho, the only drawback is that the seat has some resistance moving forward/reverse due to the rails touching slighty on the carpet. For me is not a issue.
(y)
KevC
  Clio 172 PH1
(y)
That's something I can work around. Thanks for letting me know.
Last update of the year. :).
Decided to remove the locking pins of my Sachs. Due to the state of the roads in my area (Worse and worse every year despite the tax always being higher year by year) i decided to turn the damping down a little bit.
General view of the shock
The locking allen screw
Removing it using a brand new Key
Bolt removed
Removing the adjuster being careful
Everything exposed and in need of a good clean
Everything cleaned, lubed and ready to install
Then went for a big drive, and settled with -4 clicks face to stock. It´s perfect for these road right now .
Thanks for reading and see you in 2025 !
