Discount code for Castrol oils (list needed)
Sunglasses_Ron
ClioSport Admin
I have an opportunity to set up a discount code for a Castrol oil through a contact.
What I need is a list of grades that would be popular in order for a club page to be set up for us.
Seeing as I know fck all about this subject can someone help compile a list of Castrol oils that people on here would like to be available.
Cheers x
Mr Underhill
Covers most Renault models.
Product LineViscosity & VariantRenault Spec
EDGE0W-30RN0700 / RN0710
0W-40 R / RN17 RSARN17RSA
0W-40 A3/B4RN0700 / RN0710
5W-30 (C3)RN0700 / RN0710
MAGNATEC10W-40 A/BRN0700 / RN0710
5W-40 A3/B4RN0700 / RN0710
5W-40 C3RN0700 / RN0710
10W-40 A3/B4 (Part-synthetic)RN0700 / RN0710
GTX5W-30 C3RN0700 / RN0710
5W-30 C4RN0720
5W-30 RN17RN17
5W-40 MVRN0700 / RN0710
10W-40 A3/B4RN0700 / RN0710
0W-20 RN17 FERN17FE
0W-16 AN2022AN2022
  MX5 & MX3
Castrol Transmax FE 75w is GL-4 so should be fine to use in a Renault box.
See about Castrol React SRF brake fluid too.
Is that it?
I've been looking up box oils and all I find is that and, under the power steering bracket, Dex III.
For track cars, is there an "upgrade" lube they would use? 75w/140 or such?
NorthloopCup
@NorthloopCup
Is there any Castrol gearbox oil that’s suitable to go on the list?
R
Transmax FE75 looks ok to use, and Transmax multivehicle 75w90 also looks to be ok to use.
Both oils are GL4 which is the important part for the jc5 and TL4.
Interestingly, the Transmax 75w90 is closely comparable to redline mt90 - or at least it is on the data sheets.
