Struggler
Ph1 track 172
I'm pretty sure im going to drop the sump on my track build but I've already put the head back on so cant disassemble the block completely. There is also nothing wrong with the block or bottom end bearings (i dont think) which is why i initially didnt plan on openning it up at all. But if the sump is coming off for cleaning and inspection I'm wondering if it's worth putting in some ARP rod bolts for good measure.
My question is, Is it possible (or advisable) to upgrade the rod bolts without disassembling the crank? Or would it be worth changing the bottom end bearings anyway? If even possible without removing the rods.
