Airbag Module... Handbrake wire??
Gents,
I'm in the middle of stripping the airbag Wiring out of the Clio, but the handbrake warning light wire, is wrapped in all of that wiring.
Do I need to trace this back and have it plugged in or can I get rid of it?
Mine doesn't, I stripped it out of the airbag loom and then forgot to reconnect it, no warning lights showing
i have removed all airbag wiring, heater wiring and stereo related wiring from 2 PH1 cars in the past month. On both occasions the wiring going to the handbrake warning light not being connected threw up the stop light on the dash. Are PH2's different i assume then?
I've done all the above in my Ph1 and I decided to leave the wire in , just cut and pulled the loom out at the left side of the dash .
Seems legit [emoji12]
Possibly but I couldn't say for sure, I know my stop light works as it came on when my alternator blew, may just put it down to being French, seems to explain most things ;)
Can all this wiring be cut out without in any problems?
Digging up an old thread.
I don't have the wiring since I stripped it all out but have the stop and handbrake light on. Maybe I earthed it thinking it was the right solution and forgot.
Does anyone know where the wire goes on the ph1 so I can disconnect it permanently?
