Airbag Module... Handbrake wire??
Gents,
I'm in the middle of stripping the airbag Wiring out of the Clio, but the handbrake warning light wire, is wrapped in all of that wiring.
Do I need to trace this back and have it plugged in or can I get rid of it?
scotiamr2t
  Mazda 2, Ph1 172
Mine doesn't, I stripped it out of the airbag loom and then forgot to reconnect it, no warning lights showing
i have removed all airbag wiring, heater wiring and stereo related wiring from 2 PH1 cars in the past month. On both occasions the wiring going to the handbrake warning light not being connected threw up the stop light on the dash. Are PH2's different i assume then?
  172 Ph1
I've done all the above in my Ph1 and I decided to leave the wire in , just cut and pulled the loom out at the left side of the dash .
Seems legit [emoji12]
  Clio 172 Merc ML55
Possibly but I couldn't say for sure, I know my stop light works as it came on when my alternator blew, may just put it down to being French, seems to explain most things ;)
Stuiemc
  Audi RS3, Clio 172
Can all this wiring be cut out without in any problems?
Struggler
  Ph1 track 172
Digging up an old thread.
I don't have the wiring since I stripped it all out but have the stop and handbrake light on. Maybe I earthed it thinking it was the right solution and forgot.
Does anyone know where the wire goes on the ph1 so I can disconnect it permanently?
