Rojer's 200T
Car looked fantastic on track, shame I didn't get to tag along as a passenger, one of the downsides of sessions I think.
What pads did you have in it? The PBS Prorace? I found them quite wooden in my Clio as well and only seemed to be good for a couple of laps before overheating.
Yer prorace, they were great after they got hot and then cooled off again. It would have been great to take you out. Hopefully it won't be too long before the next track day. Although I have been looking at semi slicks 🤣
  • Love
Reactions: MLB
That will be another massive step up, I went from PS3 to RSR to AR1 on the Clio and every time it was an eye opener how much more speed I could carry through corners. You'll love it!
Managed to win some cheap track wheels on eBay. I say track wheels, they are from a Hyundai i40, but for £130 they will do nicely. 17x7.5J ET 46Freshly powder coated, just need to sort out some new wheel bolts as I think I will have to remove the spacers due to the offset.
Drove to Devon last night, 9 hour round trip to collect these wheels and three are bent. Spoken to eBay and will go through their channels. £84 per wheel to get them straightened so that's a no go. On the look out for another set before the track day. I should of held off ordering the tyres, oh well.
@Rojer I Will take Photos of them in the Morning, I have just spent ages trying to find photos in my album but can't.
From Memory they are 114.3 PCD & 17 x 7 with 47 offset but will double check in the morning.
This is when I trial fitted one to my i20N in March but they are no good because the centre bore is 1mm too small.
I have had them stored in my garage since 2017.
@Rojer As Promised here are some photos of the wheels, I was slightly out with the offset as it's 49 not 47. A quick online check has the PCD as 5 x114.3 which I think ties in with the Clio & is the same as my i20N.
One has a very small amount of curb rash, Would you be happy with £40 just to cover the scrap Value of them? If so PM me. They aren't perfect but not shabby by any means.
Some good news!
eBay refunded me for the bent wheels, so I will relist them honestly this time and hopefully get £50 or something.
Wanted to say a massive thank you to @Andy P I collected the Megane wheels last night and they are mint. Even gave me some wheel bolts to use without my spacers. Lovely chap and if I didn't have to get back, we could have stayed chatting for hours. CS at it's best when it's helping others.
Some good news!
Wanted to say a massive thank you to @Andy P I collected the Megane wheels last night and they are mint. Even gave me some wheel bolts to use without my spacers. Lovely chap and if I didn't have to get back, we could have stayed chatting for hours. CS at its best when it's helping others.
Nice to meet you @Rojer too.
You are welcome, it was a pleasure to be able to assist. I think you may have been a lot later home had we continued chatting 🤣.
Test fitted one of the wheels, but I'm have a bit of a mare with the bolts.
Genuine is on the left and the ones Andy gave me on the right. When you put them both through the wheel, the ones on the right stick out about 23/24mm on the back of the wheel and the genuine ones sit about 19/20mm. Called up Renault to confirm the part number and they say its 7703003008 but that doesn't have the movable collar like the current genuine ones I have.
If anyone has any bolts laying around let me know, I will probably order some that match my current genuine ones just to be safe.
I don't get the issue Rojer
The one on the left has the collar 5-6mm higher than the one on the right so the right one would stick through the wheel more...
The one on the right bottoms out in the hub before it tightens up against the wheel.
And you don't have enough of the bolt on the left?
The left one is correct, I just don't have enough of them because they are only fitted to the rear due to running longer bolts on the front for spacers. Now I have removed the spacers To fit the new wheels, I don't have the right bolts to bolt them on at the front.
