1.2 and 1.6 suspension sizes
Car  RB 182 cup
Hi guys,
trying to get a bit more information, I had a mk 2 ph 2 1.2 16v with coilovers on, I've been told the bolt spacing on the front struts are probably 58mm, the ph 1's are 52mm if that's correct? I now have a mk 2 ph 2 1.6 16v and apparently these have a bolt spacing of 58mm too? My 1.2 is an 02 plate and my 1.6 is a 52 plate, will these both have the same size bolt spacing as I want to swap the coilovers on them.
thanks for any help, Blane
Just checked this on Dialogys for you pal
CB05 (aka 1.2 16v) Phase 2 - Spacing is 58mm knuckle part number is 8200207307
CB0T (1.6 16V) - Spacing is 58mm knuckle part number is 8200207307
Just tried fitting them, the hub is different, on the 1.2 the hub is 7/8 of an inch and the hub on the 1.6 is and inch :/
