1*2 Brake Fluid Reserviour - What is the...
Car  172
Reserviour inside a reserviour?
The brake fluid & fluid level sensor are inside a roughly 30mm "pot," but what's the purpose of having this inside a bigger reserviour?
Is there supposed to be fluid inside both parts or just down the middle?
Where are the min & max level indicators?
Thanks in advance!
it's fluid stabilisation. if there wasn't anything around the level sensor, the warning light would come on every time you accelerated or went round a corner
Hmm fair point, thank you. Seems a poor design in the first case then.
Are there min/max marks on the inside/outside of the reserviour?
Do some reservoirs have another pot so if part of the split system leaks, the other half still has a reservoir of fluid?
