1.4 clio hard start
2002 Clio 1.4 16v hard to start when cold fine when warm, runs lumpy too
Changed plugs and fitted new tdc sensor still not running right
Any suggestions,?
  MG ZR 1.8
Mine did that when I first got the 1.4. The throttle body was clogged, take it out and give it a clean
  Racing Blue Clio 182
Once you've clean out the throttle disconnect the battery and leave it for a while the reconnect and start to allow the ECU parameters to reset
Took plenum and throttle body off, found big carbon build up in throttle body. Cleaned all up and replaced coil packs and spark plugs, new tdc sensor an cleaned MAP sensor.
Car now starts up fine, with no hesitation, but still slightly lumpy. what else could this be?
