1.6 to 2.0 engine swap
engine, front track, disks, suspension etc etc, exhuast, ECU, air con put in if u have it. wiring loom etc
Edit interior dash for the 2.0 engine.
Depends what you want to use what you already have etc.
Its a lot of work but you can do it in a week.
  Merc Coupe V6 AMG
i have a clio dynamique, lowered susupension. custom exhaust etc etc. how much to fit you reckon?
suspension will have to be changed for 182/172 suspension. exhaust will have to be changed/modified, u should get a 182 manifold and cat and then work off that.
you could do with the radiator from a clio rs aswell.
depending what you go for, gettin an engine and all the bits from a 182 could be 2k overall costs will mount up to about 4k.
get a written off 182 from ebay/breakers and transfer all the parts over that way you could get a nice leather interior aswell.
You need a load of bits for an easy conversion ECU, UCH all the wiring looms dash, suspension arms dampers hbs calipers etc. You can get the engine and gearbox make custom shafts etc and have the stock ecu reporgrammed with a custom loom but it would take ages.
£750~1.5k for fitment depends where you go you might find a tunners whan to learn how to do it (ktec wanted £500 some time agao so they could learn how to do one) however some places might say £3k.
