12x12" of 3m carbon vinyl what should i do ?
  astra gsi/cliosport 172
As above i have already done my badge`s front and rear and hazard panel so what next i was thinking the bullets but would be quite hard due to the 2.0 16v and would not be perfect .
Ideas and pics welcome but remember i only have 12"x12"
  Honda & VW
As long as the sheet is heated up doing the bullets shouldn't be a problem, keep heat on it to prolong the 'play' time.
other than that, the usual like gearstick and steering wheel inserts.
i just dont think i would get it perfect. i have done it before but i dont know how it would come out might give it ago and i really dont want to do the gear or steering wheel parts as i like them the way thay are
  corsa D / 172 clio
just one quick tip DONT HEAT IT TOO MUCH;)
when it cools down it shrinks back and goes a bit hard(can be re heated tho):D
Yeah ive done a few bits already (ps controler etc) and read up on how to do it etc
Ive did the front and rear dimonds a couple of weeks ago but today i ended up doing the bullets which was easyer than i thought .
Ive still got some left so might do the dimounds on the wheels like you have done do thay just pop off or is it a sillicone back on job?
  corsa D / 172 clio
the wheel diamonds come off the same as the rear diamond
they have 4 heat welds on them just gently cut the weld and they will tap out mate.
