13psi of B18FT Boost
Grabbed a few pictures and videos of a mates recently finished Mk1 with a Volvo B18FT engine - plenty of fun for something which has cost pretty much nothing to do in comparison to some builds!
Bit of a video to come later.
It could be anywhere between 150-160bhp at the moment from research, he keeps playing with the boost controller etc. The Volvo ECU has a boost cut/limiter at approx 14psi - but once thats removed from the ECU anywhere upto 190bhp is possible apparently!
Just needs a new set of brackets making and painting black really, its just being driven for now to test everythings ok :)
When you say cheaper than some builds . . . ;)
Looks good. Wasn't this the original thing to do back in the days of that electric blue valver with the turinis?
Yeah - its quite a common conversion, alot have done it. Engines can be picked up cheap, easy to get power from etc
seen a few of these knocking around quite cool
if you have a volvo donar is it a pretty straight forward job foxy?
Same basic lump as the RSi IIRC, so just a case of plumping in the electrics and boostpipes
elecs and unblocking the ecu are the hardest bits.
everything else is just swaping over rsi/volvo bits, easy conversion to do....
