doing it on first second and third wos nat really needed
if you can, try making runs on different gears and see the ifference in power and torque.
tthen its important to pick the engine speed accurately - best would be not from rev meter read-out - which is not very accurate, but from wiring...  calculating from gear ratios is also quite difficult - because you have to measure real circ. of your wheel to get accurate. Easy step is to go to your friendly renault dealer link to the computer, rev it to the limiter a couple of times, and check when it comes. then make sure that on RR it cuts out on the same revs (calculated by RR)
all these things create small differences that sum up and can become quite big
WHEN ON RR ASK FOR:
lamda read-out.
power at wheels graph and values - this is the most important thing - most accurate and gives real idea of how your car goes. there is less posibility to tamper with the results (it is often one click to make power go up or down significantly - its all the matter of RR software afterall)
if you want an idea of est. power at the flywheel ask for transmission losses graph
its best if you get combined - power at wheels+transmission losses+power at flywheel +torqe data.... or even better divided - power at engine+torque and power at wheels+trans.loss+power at flywheel - ask for possibly similar scale...
cheers and good read-outs
