16v feul pump problem
parked up the clio for about a week and a half,went back to it yesterday to start it,when i turned on the ignition the fuel pump didnt energise.checked that there was power going to it and there is,it seems obvious that the pump must be f**ked,but how could this have happened when the car wasnt even in use?!any suggestions or ideas as to what else on the off chance might be wrong before i shell out for a new pump?
Check the middle relay in the group of 3 identical ones in the aux fuse box under the bonnet (near the n/s turret)
Take it out, and replace it with another one.
Had this very problem a couple of days ago.
Paul
checked the relay,swapped it with another and still no go,even tried bridging terminal no.3 and 5,doesnt energise,same when i turn on the ign,theres power going to the pump alright but no go.how much would you be looking for a pump,its the later type with the 5 wire plug,1993
