16V Gauges in an RSI
Car  mk1 RSI
Hi Guys
Got the dash top, clocks and gauges of a 16v.....fitted em all easy enough.....temp gauge and oil pressure temp dont work a i expected.......question is the gauge seating......should there be a frame to secure them to ?.....and a piece that fits inbetween the clocks and the gauge housings ?....
yep there is a small frame, its revieted to the top of the dash. unless you know of a 16v in a scrappy, the only place you will get one is renault.
Cheers GEEZER.........is the panel that closes the gap between the clocks and gauges attached to the bracket do you know ?
