I'm a bit worried about mine maybe having gone as there sems to be a bit of oil leaking from above where the flywheel is. A few questions:
How long have others taken when replacing theirs before?
Are there any good guides anywhere, or should I just go by the haynes?
When removing the head is it easier to just disconnect the manifold from the downpipe rather than the manifold from the head (because of the rusty bolts holding it into the head)?
What other seals/gaskets should I replace?
If the head needs skimmed how much is that likely to cost?
Anyone used one of the kits off ebay before?
Thanks.
Thanks.
