Would a knackered ISCV cause poor fuel consumption on a valver? If not, any ideas what could? Thanks
J James Clio 16v Clio Mk1 Hybrid Jul 28, 2005 #1 Would a knackered ISCV cause poor fuel consumption on a valver? If not, any ideas what could? Thanks
B BRUN Skoda Fabia vRS Jul 28, 2005 #2 not really no when was it last serviced ? plugs, air filter, dizzi cap, rotor arm etc fuel filter is one everyone forgets about and is quite easy to change (if i can do it anyone can)
B BRUN Skoda Fabia vRS Jul 28, 2005 #4 if they are not in very good condition then the mixture wont combust properly because of a poor spark
J James Clio 16v Clio Mk1 Hybrid Jul 28, 2005 #5 Done all that lot. Serviced a couple of weeks ago. Im a bit stuck to what it is.
J James Clio 16v Clio Mk1 Hybrid Jul 28, 2005 #7 Yeah, I do have, but no heavier than 6 months ago when I was using less fuel.
N number1 Clio Mk1 Hybrid Jul 28, 2005 #8 coolant temp sensor? if these go then they can cause idle problems aswell as high fuel consumption, Dave
J James Clio 16v Clio Mk1 Hybrid Jul 28, 2005 #9 Replaced that. Im starting to wonder if it was faulty.
B BRUN Skoda Fabia vRS Jul 29, 2005 #10 i dont know if it can affect fuelling, but, the TDC sensor is very easy to replace and is a common fault also the air temp sensor on the inlet manifold, be careful not to damage the pipe thats next to it
J James Clio 16v Clio Mk1 Hybrid Jul 29, 2005 #11 Thanks I will try them. Any idea how much they are?
