172/182 inlet manifold?
Car  clio sport 172 cup
as above are they any different? would i benefit ftom fitting a 182 inlet to my 172 cup? or would i be just better off getting my inlet matched?
Thanks lee
the 182 upper WILL fit. Requires one hose take-off blocking, and you can't fit one bolt (insignificant). Not that it would give you an improvement on a cup.
Matching would be the way to go
How long does it take you? where abouts are you and what sort of price would I be looking at, Cheers Danny
the process of matching using a CNC machine doesn't necessarily make the matching better than doing it by hand, it's just a fast, and very repeatable process. Only the lowers have ever been CNC'd by anyone, the upper is normally either not done, or matched by hand anyway
Ben@ Angelworks is doing mine for my ph1 starting off with the RS lower then opening that one out even more plus the upper.
hmmm i noticed the upper part of mine has a bolt missing? so i wonder if its already got a 182 manifold on.
