172 Backbox removal?
  ClioSport 172
I'm having a little trouble removing the backbox of my 172. It snapped last night and i've another on order. The rubber seal is almost perished tho...and i'm unsure how u seperate it from the backbox itself? Any suggestions would be a great help! :)
  RS Clio 172 Cup
When you say rubber seal?? Do you mean the rear exhaust mount thats holding the backbox up.
If so, the mounting has 3x 13mm (IIRC) bolts, either undo them slightly, so it can slide forwards/backwards off the hanger, or undo them completely to remove the mount.
If the rubber inside the mounting is perished, then its time for a new rear exhaust mount. Think they are around £10 new from KTEC.
Mark
  Astra 1.9Cdti SRi
Not sure if yours has it but on the hanger that goes through the mount there might be a bolt stopping you from removing the back box, you need to go under the car and look behind it, mine has and its a small 8-10mm one,
  ClioSport 172
Yeah its the rear exhaust mount i'm meaning...i tried loosening it and it seemed to get tighter....and yes, i was turning it the correct way, lol. I may try and just take the whole exhaust mount off. The bolts seemed astho they were welded on tho....need 2 put abit more back into probably. Thanks for the advice.
  RS Clio 172 Cup
Try spraying some WD40 and leave it for awhile. I undid mine the other week and though they was tight on, a bit of the classic 'WD40', made them awhole lot easier to get off.
  ClioSport 172
Spot on lads....cheers for the help. While i'm at it....any 1 know the part code for the rear mount?! Cheers
  Astra 1.9Cdti SRi
^ just go on North west performance website and its about £10, dont go to renault as theyl just rip you off
  ClioSport 172
U don't need to tell me that....they have a bad rep in the highlands of Scotland. I know a lady who was charged £140 for a new battery! :eek: Daylight robbery!
