172 burning smell **
Errr just drove to the shop for lunch..... and on the way back got a strong burning smell. Got back to work and opened the bonnet, there is a strong burning smell coming from the back of the engine bay.
As well ive noticed the exhaust is a bit louder, ie when i lift of the throttle it splutters a bit?
Any ideas/?
you been riding the clutch, did it feel slightly more sluggish than normal, your clutch could be sticking / slipping, causing that smell...
hmm, all the same after the last one went up in smoke I would be cautious.
ps. Did we ever find out why that other 172 went up ?
I would say there is an oil leak, but then that wouldnt make the exhaust louder, hmmmm.
check you oil level to see if its buring oil and also check that there is water in your radiator cos if it over-heats then your head will blow.
Now you mention it the clutch has been a bit cack for the last few weeks, bitting really near the top and jerking now and again...?
Would be the case on a 4month old car with 10kmiles on it?
