hi evry1 got maself complete lot of 172 runnin gear mechanical is easy is it just plug and play wiring wise anyone done it before thanks lee
Its a pain forget it get a 172 much cheaper.hi evry1 got maself complete lot of 172 runnin gear mechanical is easy is it just plug and play wiring wise anyone done it before thanks lee
make sure you under dash loom from your Donor car fits you existing rear loom
Doddle matey. Did this one back in 2002 - as Freddy said make sure you get ALL the wiring from the donor car and a complete ECU kit.
4 hours? Even I can do it in lessapart from it takes about 4hours to do 21wires! cough MATT!!! the loom you gave me wasn't out of the donor car (understandable!) but some honnesty would've been nice you dodgy northerner!!!
Theres a thread on Seat Cupra.net wheres someone was raced by him shocked how some old CLio kept with his 280hp or somehting car. That was before Matt realy tunned it and stuck the 1.8T in and tunned it to 425hp or so.I would loved to have seen the faces of some people who laughed at you at the lights etc....before you blew them away! Class!
1.4 I think.it's a 1.2 sleeper![]()
^ the badge clearly says 1.2 edde, you need new glasses more than me*squints*
You need the dahboard as well easy way to remove the whole darn thing only a few bolts etc hold it on there there the connections for the doors there the one on the passenger side down by the bonnet release for the rear looms and one for the airbags from memory.as per usual changed mind again i cud do with a wiring diagram on the conversion if anyone has any clues pm'd matt black mite as well do the conversion the car stands me to 1200quid all in n i payed 850 for wat was left of a 172 from simpson salvage just gota go back and get the rest of it next w/e it started to rain so dint bother removing a rite lot of the loom just the engine bay car has my name on it n do not touch hehehe
Uch isn't needed in a phase 1 transplant though Fred.you need the following from a donor car (172/182)
dash wiring loom
engine wiring loom
UCH
ECU
decoder ring
key
If i wanted to put a cup engine intomy car what exactly will i need? Could i use a standard 172 engine and remove air con pumps to make it effetively a cup engine? sorry for the hijack![]()
dash wiring loom
engine wiring loom
UCH
ECU
decoder ring
key
i think thats all
Bump!
I'm intrested in purchasing conversion of you for £1500 (Matt)
You intrested in selling?
Tried to send you a PM a few times but your inbox is full.
