172 Cup / 182 Servo
-Dan-
Wondering, If someone can confirm if the servos from a 172 cup and 182 cup are the same,
I'm buying a 182 cup to replace my 172 cup and have removed all the brake lines/ loom etc to eventually remove the ABS from the car but for now was wondering if I can just swap the MC over and block the 2 ports that are not used on the ABS set up, only reason is a have 197 brembo setup ill be transferring over and don't fancy the longer pedal travel reported from doing so on a 182.
Cup was stop on with no extra travel in the pedal.
Dan.
