172 Cup Gearbox Issue?
Car  Kawasaki ER6N
Had the car on the ramp today after noticing a clicking when I lift off the accelerator and when I spin the drivers front wheel its normal but when I spin the passenger wheel I get a squeak/click coming from the gearbox and if I look at the area the drivers shaft goes into the box can see it moving back and forth a few mm.
If you pull the drivers shaft away from the box you can feel it pulling towards the box but the noise stops.
Any ideas or is the box dead still drives fine just makes a few clicks when I lift off and squeaks when I spin the n/s wheel.
Sounds like maybe your drive shaft could be worn mate the clicking could be the splines slipping on the teeth
