right my 172 cup used to rev to about 7.4 rpm and now it seems to have lost some revs :S hitting the limit at 6.8 rpm now, anybody got any ideas as to why its doing this now?
hi whats a coolant temp sensor problem. as mine has a coolant symbol come on at the side of the speedo . where is the sensor on the engine... thanks garry
Max. engine speeds for a coolant temperature < 75°C 6,700 rpm
for a coolant temperature > 75°C in 1st or 2nd gear 7,200 rpm
for a coolant temperature > 75°C in 3rd, 4th or 5th speed 7,000 rpm
Could be CTS, or thermostat, does the needle sit just above or just below or bang on in the middle?
not sure mate but the dephaser is quite noisy when engine is warm,so i know that is could possibly need changing but got some oil and filter and a flush today so ill get that done at weekend and see if it helps at all,also got a new cts so ill whack that in also.
mine has a slight MPG problem. it revs to 7250 though, but the temp gauge on the dash keeps moving from just under the middle and back to the middle again (even after 1 hour of normal driving)
what should I look for at first? (lambda will be changed in the future) are these symthoms likely related to the CTS or the thermostat?
thx!
Changed today these two, here are the part numbers if anyone's interested:
thermostat: 8200 772 985
CTS: 8200 561 449
thermostat gasket: 8200 267 272
the new thermostat came with a new gasket (wish renault knew that before advising to buy it! )
