93keith Car clio cup 172 Apr 20, 2011 #1 In process of fitting frt brace,do i have too drop struts too line bolts for brace,or is there an easier way.advice needed.
E Emma. Car 172 Cup Pug 208 Apr 20, 2011 #2 You'll have to drop the struts to put the bolts in unless your using self tappers.
chris powell Car corsa D / 172 clio Apr 20, 2011 #5 undo the top nut that you can see under the bonnet. it will still be tight tho!! i would just remove it all together mate its only 2 more bolts (ok maybe a bit more than that but still worth it to get it right)
93keith Car clio cup 172 Apr 20, 2011 #6 Just tried too undo the top nut(its f$$cking tight)seemed too twist struts.think ill leave it till tomorrow.
montana Car Clio 197 Apr 20, 2011 #7 93keith said: Just tried too undo the top nut(its f$$cking tight)seemed too twist struts.think ill leave it till tomorrow. Click to expand... you need to secure the strut insert with an allen key while undoing with a ring spanner, it won't twist the strut then
