Sounds a lot that - going by Renaults performance data stats, it dosent seem to make much of a difference in terms of figures but would it be a advantage for folk to have a ph1 172 head on their 182 etc or have the exhaust ports opened up a bit?
Always wondered if i did the right thing having a ph2 head ported and put on my ph1
The phs2's head is a diff casting and doesnt have the ex ports CNC'd like the phs1's.
Performance is not affected as the engine output is not at a level where the flow ratio becomes a hinderance.
You can have TOO much exhaust flow.
The phs2's ports are also different in their internal geometry so you cant really make a phs2 into a phs1 ex port as ALOT of material needs to be removed.
