172 fault codes
Car  Clio 172 Flame Red
Plugged in my rs tuner and its bringing up :
DF0018, DF0082, DF0601 front O2 heater fault
DF0018 Front O2 heater fault on activation
Does anyone know what this is ?
Is it the o2 sensor ?
It's the heater element that's not working.
Check the wiring is okay and I'd so swap the unit out for a new one.
The heater element for the Ho2 sensor is part of either the upstream or downstream senors (which in this case is the upstream/pre-CAT sensor)?
The first thing you should do in this case however is check the wiring to the upstream sensor as they have a habit of getting burnt or crudded up. If all looks okay, inside the connector and out, replace the sensor for a new non-universal unit.
Mick
Cheers Mick will go check them now , what do you mean by new non-universal ? OEM part ?
By non-universal I mean anything that's not a cheap copy or requires you to cut and solder wires to your existing plugs.
You should be able to pick up an NGK/NTK item for under £100 and they're quality.
