172 ff gearbox
Car  172 FF and Fabia VRS
Is it right what i read about the 172 ff gearbox i can out a cup box in the car??
need to be a gearbox from another ff
thanks
feebs
you can use a cup box, you just wont utilise the speed sensor as it's taken off the ABS. You can't do it the other way round easily
You can stick any JC5 into the 172 providing you check the speedo drive. If yours has a speedo drive you will have to fit a box with a speedo drive. If your speedo is taken off the ABS system you can fit anything. Keep your eyes open for a JC5 129 or a 130. Be careful of JC5 132's & JC5 125's as there for diesels and will mess your gearing up. Whatever you find pm me and i will give you the ratio's and tell you what the box is out of.
