172 fitting 182 manifold
P
phill172
Has anyone here fitted a 182 manifold to there 172? if so how much did it cost to fit, what sort of work was needed, and was it worth it?? thanks!
you ment exhaust mainfold right?
if so, so far I hear and think, the only problem is that you must " cut " a peace of your exhaust pipe, because on 172 clio's the exhaust mainfold is " shorter " then 182 has, on 182 cat is closer to the center of car, and on 172 the cat is closer to the engine... ( on 172 you have 4-1 exhaust mainfold, and on 182 you have 4-2-1, so on 182 is longer )
and that is about it...
in croatia that kind of job cost about 40€
