172 front bumper removal
Car  172 y reg flamer
done a search for the guide in the guides sections but i cant find it.
anyone point me in the direction or have a guide to post
easy mate
you need to take the arches off first inc all attatchments to bumper
that exposes two bolts under there (inside the arch/bumper meeting point) 10mm ones undo those first
pop a screwdriver between the arch/bumper (carefully it will take paint off!)
do the same both sides.
that should pop off no problems then.
It's gettin the arches off thats a b*tch
I got blood blisters on my fingers from takin mine off! lol
Hope that helps.
chris
You can do it without taking out the arches. Just gently prise them back to undo the 10mills. Dont forget the torx screws that run in the arch and a few underneath. Also the 4 10mm's on the undertray and the 2 clips under the bonnet on the grill panel.
Or I could show you if your around the corner.
Shaun
cool thanks guys
arch's are already off, guy who had the car befor me took the xenons out cos of the ballast. under tray is off too :)
just the 2 10mm an it should pop off then
cool thanks guys
yup yup each side and as usual with renault just the crappy plastic clips everywhere!
good luck;)
cool thanks guys
no, there's 2 10mm either side in the arch liners. another few screws under the front lip by the splitter, 2 bolts in front of the undertray and 2 pop up clips under the bonnet above the grille.
there all already off mate, no arch liners or undertray on and the clips under the bonnet are missing. so it'll just be the 2 10mm's
