172 gearbox or clutch noise
Car  E39 530i
when driving in 2nd 3rd or 4th but it's loudest in 2nd and 3rd. When I sink the clutch I'm starting to hear a loud wearing noise, it's hard to explain, it's like a wineing/shuddring noise always hear its when I change from 1st too 2nd gear, and 2nd too 3rd.Car has done 62300 miles. Gearbox going. is this a common problem.
Y reg 2001 172
Yeah release bearing mate, mine is the same, been like it for ages, i don't think there is much you can do apart from deal with it until you need the clutch doing, as its quite a big job to sort it!
Mine did this with a brand new gearbox and clutch in, quality Renault parts.
Turned out to be the gearbox in the end.
Is this like a short loud "grunting" sound you can hear over the revs when accelerating in 1st?
I'm getting this in mine, only got the car so unsure what it is & if it's normal or not :S
cheak the gearbox level and top if if needed.
Could be the thrust release bearing but I'd think its the gearbox or selectors.
Mines the same :( wearing noise when clutch depressed and loud rubbing when brought up to the bite point. Only had the car 6 days!!! anyways its going into renault on thursday i'll update with the cost !!! :(
:dead:
Hi all like i said, went to the stealership today. First thing they say the usual... If we do the work the diagnostics are free. if you take it elsewhere £85. Already im on a downer :( Anyways 4 hours later i get the call. They suggested that the whole clutch assembly needed to be replaced. Total cost......... £865!!!!!!!!
So i picked up the car £85 down :( took it to a clutch specialist to look at. They are fixing it for me next week for £285.
I feel abit unsure about 3rd party gararges but ill let you know how it goes
Mike
