172 gremlins
Paul172sport
Car  Sunflower Ph1
Thoughts please. Ph1 172. Turns over but won't fire up.
I've had the interior out recently and dash top is off. However it has run since doing this.
Noticed today the central locking isn't working either
The immobiliser light does go out OK.
Any thoughts were to start looking?
Mine did this a few weeks back was the fuel pump relay in the box by the battery. Pics of the on in my 172 thread
Updates.
No I don't hear the pump on ignition....
I've swapped the relays and no luck. Is there another fuse to check. I don't think so?
Tdc all looks OK.
The immobiliser light goes out and the light by gear stick blinks OK too.
I presently have the top of dash off and steering column surround. I'm sure it ran OK before like this. Just clutching at straws now
Could you check if the fuel pump is working by attaching a battery to it?
That would help work out if the fuel pump is dead or if it's just not getting power.
I’d check this.
Mine did the same and the fuse box under the bonnet was a bit corroded where the relays fitted in. Removed and sanded off all connectors and it fired up.
