172 Misfiring
  Ph2 172
More problems with my car :dapprove:
I had my coil pack go a while ago, when I had the new one fitted I was noticing that the car had a slight misfire at below 2000 revs, which got more noticable as the car got hotter. I put it down to another dodgy coil pack and replaced it on Wednesday hoping it'd be alright. But I'm still getting the misfire.
It's better than it was before, but the misfire is still there and I don't know what to do. I've pretty much run out of money repairing the car over the last couple of months so don't want to replace everything just in case.
I'm thinking that it could be plugs so was going to try those this weekend. Anyone else have any ideas?
  m-tec bmw 325 ci spo
when u change coil packs ur susposed to change them all at once or two at a time other wise they all start to fail one after another
MRBILLYUK
  FF Jeden Osiem Dwa
So above 2000 revs the engine runs fine ?? On my old 172 it was hesitating below 2500 revs above that it was ok . Turned out to be the plugs .
  Ph2 172
Yeah my coil pack isn't like that, its just one unit which sits at the back of the engine and all the HT leads go into it
  Ph2 172
Runs perfect above 2000 yeah. So plugs sorted it for you then? Looks like the way to go, especially as they're cheaper than the HT leads! Recommend sticking to the standard plugs or are there better ones?
MRBILLYUK
  FF Jeden Osiem Dwa
Just standard NGK PFR6E-10 plugs
  Ph2 172
Cool I'll get some plugs tomorrow then and see what happens. If not, I'll have to do the leads. Would be nice to be able to do something simple to fix a problem for a change, I swear I own the worst 172 in the country!
  M2 Competition
Whats it sound like when this happens?
Is it like the throttle sticks, and it burbles and spits for a bit?
  Ph2 172
its not like the throttle sticks no, it literally just sounds like its misfired, like its cut out for a split second. No spitting or anything
  Clio 182 Trophy. No. 189
check your ht leads are not arching out on your plenum thats what caused a missfire on mine
Replaced my plugs today and had similar issues from standing or hill start. The leads looked like they had slight grooves in them so wondering whether to replace them?
they normally do but if they touch the plenum the ark out and cause a miss fire they should have a protective rubber sleave over all the leads
  GDI Demo 182, Rsi Spider
get it to someone with decent diagnostics... will prob cost you less than guess and replace as it should narrow it down to a specific problem..
may find they may even lend you a set of plugs to see if it cures it
Have not tried the leads yet but wondering what affect blocked / weak injectors may have? I do run the car low of petrol often :eek: so wondering if my problems may be fuel related?
Injectors can block but as for running low whilst not good practice I woulnd't worry
