172 Mk2 - Lumpy when cold
S
scottyboy1972
Hi,
Just wondered if anyone has had a similar problem with a 172 Mk2.
When running from cold (in morning seems to be worse) , car runs very lumpy and seems to have a lot less power when accerlating (flat spot), but once up to running temperture it seems to be ok again.
I do notice the exhaust seem to make a lot more noise when cold, as if its blowing, but i got this checked out and the garage couldnt find anything, although they did say that tapping the mid section box would reveal a rattle inside.
its off to renault on friday to be looked at just wondered if anyone else had similar problem before i get stung by a big repair bill from renault.
sn00p
  A blue one.
Normal, from a cold start it goes into tree hugging mode where it limits emissions. It also lowers the rev limiter, but you shouldnt really be going near that from cold!
  7.6cc :D
I think its pretty normal, my car hates mornings and cold weather, complains and acts like a Kangaroo for the first five minutes, then once the temperature is up hes fine!
  133/225/CLS AMG
Ive always found the Clio twitchy when they are not warmed up. I drove a 1.4 Alize and that was really hard to drive smoothly.
Took 15,000 miles for it to drive as Id expect. Im expecting my 172 to loosen up when it gets there as well.
sn00p
  A blue one.
Quote: Originally posted by AlexJMills on 25 April 2005Took 15,000 miles for it to drive as Id expect. Im expecting my 172 to loosen up when it gets there as well.
This is different to the engine loosening up over time.
The engine management goes into a mode (when cold) where for a couple of minutes the engine judders and theres a massive dead band on the accelerator.
With regards to the original poster, Im suprised (or not! its renault after all!) that your dealer isnt aware of this normal behaviour.
Ang
  Pink/Blue 182
mine does the same...kangeroo effect thing.....perfectly normal...its fine once it is warm
KDF
  Audi TT Stronic
Quote: Originally posted by bean on 26 April 2005
Mine is the same, when its really cold I find the trip meter like to reset itself! :confused:
My computer was re-setting itself for ages, then I found out why when the car refused to turn over. Dead Battery. Not saying you have the same problem but worth keeping an eye on.
Soon as I fitted a new battery it hasnt re-set itself since.
Thx, Ill keep an eye on that although Ive never had problems starting the car.
The trip meter only reset when we had snow, zero degrees or colder. I thought it was funny and put in down to French build quality :p
