Clio 172, Nissan 300ZX
				Lots of questions.
My 172 ph1 gearbox has died and I'm wondering what the options are.
I've heard the early 172 boxes are a bit weak so is there a better replacement?
Someone said the 172 Cup box will fit? Is this a different box to the standard ph1 unit?
I read the later 172 and 182 boxes have different speed sensor fittings so aren't an option without replacing clocks etc.
What exactly would need changing and is it a big job?
I'm pretty good mechanically after rebuilding my Nissan 300ZX from the ground up over 10 years but not really worked on any other cars.
Also is the standard clutch the best to go for?
My car has a straight through exhaust, chipped (not sure which) and was told the cams had been done but I doubt that myself.
The current clutch felt pretty standard but I've not driven any other Clio's.
Thanks,
Chris.
Thanks,
Chris.
