172 PH1 - OEM suspensions are better?
Car  172 ph2
Hi
Got 172 ph1, Now i have KW suspensions which are too stiff and low for me, Also in hard turns the wheels scrapes in the wheel arch.
But in truck i have good gripe of course.
I bought a second-hand oem suspension + springs.
How is the oem? is it make the car really high? The roll angle is big?
I go to trucks only about 1 time in month
Thanks !
I can tell you from experience that Koni yellow shocks + standard springs is awesome. plus you can play with the stiffness.
Also Koni yellows + Eibach Prokit is also a good setup. both are comfortable.
Some people run Koni Yellows with Eibach sportline and I feel like the car is too lowered on public roads and you can feel every bump on the road. But on the track it's awesome.
with the koni's on around 50% stiffness it's very comfortable while still being stiffer than stock.
OEM is good but tend to leak if im not mistaken , and they cost kinda like the KONI's so no reason to not pick koni.
