172 phase 1 airbag resister trick, possible or not?
Car  Clio 172 phase 1 sc
I've seen threads on here with phase 2 models getting rid of the airbag light with resisters is this same technique possible with the phase 1 model.
i did take my car to a "specialist" with the clip tool to have to switched off properly but a good few quid and an hour later I was told it was not possible.
if anyone has done this any info would be great.
No airbag has triggered I also had a spare airbag ecu from my old Clio that I know was fine.
i won't be going back to that garage anyway!
I failed with my ph1. In the end I just cut a wire on the airbag ecu. No more lights but I have removed all the airbags
No idea. Probably not, but it passed the mot. I have no airbags so they can hardly fail it if the light doesn't come on and off
Just like to bring this up again, has anyone got rid of the aig bag, serv light on a phase 1 Clio 172 I spent a couple of hours today with no joy all the restistors have a solid connection.
does anyone know if I could send the aig bag ecu to someone with clip to sort it that way?
I have the exact same issue on my ph2 , 1 resistor on each airbag connection and still the light comes on ! no idea why ???
