172 Torque Values - Gearbox, Clutch, Driveshafts etc
I am going to be refitting my engine soon c/w a new clutch kit.
Does anyone know what the following torque values are ?
Gearbox bellhousing to the engine block.
Clutch pressure plate that holds clutch
Driveshaft at gearbox end on passengers side
Hub nuts
Engine Mounts
If anyone knows any other torque values that may be relevant.
Post them up :cool:
Search for the workshop manual, they are all in there. Drivers side engine mount bolts are 65Nm and front hub nuts around 270Nm iirc.
The only thing that I torque up are my drive shaft nuts and my head gasket + my timing belt :o. The rest is all done by my air tools . Don't expect they torque everything up in you local garage ;).
