172 TURBO!!
  Corsa 2.0 16v baby
ok i heard that the megane 225 uses a 172 engine is this true??
if so then what parts do i need obviously the manifold, turbo, cooler etc, what about pistons are they the same (doubt it) compression? etc
ohh and ill need a dump valve :D
clio with 225 bhp = laters mr imprezza/r32/ctr etc
Gunna sort out a test drive of the Megane 225 and the 182 tonight when I pick mine up from its service.
  Corsa 2.0 16v baby
dammit i got moist for a min then, teach me to listen to ford enthusiasts :cry:
any idea how much itll cost?
Might as well just swap the engine if you can find one. Im sure someone will do a turbo conversion for your engine. Aint gonna be cheap which ever way you do it.
Lee
  BMW M2C
They might think you our just there as a test pilot if you want to drive them both. lol But then Dansta seems to get away with it. ;)
Tom
  EV (s)
nah the megane 225 engine is an f4 engine but its not a 172 engine with a turbo. simply slapped on
i thought it was a turbo vairant of the 136bhp vvt
  Corsa 2.0 16v baby
can bits be used on the 172 to help with a conversion? any mechanics/renault heads out there.
Well.... interesting..... there are three cars running turbo variants of the F4R engine in the renault range... the Vel Satis, Avantime and the Megane RS....
The blocks are stronger designed, sumps are baffled, pistons are lower comp... etc etc etc.... lots of differences...
I beleive that they are based on the lower powered none vvt versions of the f4r blocks
Tom
  EV (s)
I thought all F4 engines had vvt?
the 2.0 in the laguna produces 140bhp (i assumed this has vvt)
the 2.0 in the megane produces 136bhp (but has vvt)
  Golf Mk6 Oil Burner
Im sure it wont be long before a 225 is smashed up + written off, engine dropped in a clio, chipped etc.. that would be a f**kin beast!!
  Clio RS 172
Hmm if its the same as the F4 engine the cranckshaft should fit the Willi and the F7P engine... heh!! Anyone knows what bore the RS drives and other engine specs?
:D:oops:
oh and afaik it is the avantime engine mega tuned.
And lol at Rob. ;)
  Clio RS 172
Roamer: Was told yesterday that the crank on the F4 will have a displacement og 82mm instead of the F7Ps 82,5mm. And it should fit firmly in the bay. I will let you guys know when i get my old engine out an splitted into atoms. just got a new engine with only 50.000 mph on the clock. So i gave up on restoring the old in the bay. So its gonna become the turboproject with prob. a F4 crank an 82,7 pistons and willy pistonrods. ;) Spesso head ect ect ect...
All sounds good but there will be other considerations...can the driveshafts cope, is there enogh room in the bay...not much at the moment. is the shell able to cope with increase in torque and power, or will it rip it apart, seen this on a gte turbo.
Brakes good enough? etc etc
Another thing, the traction will be a nightmare too.
Have dabbled with nova gte turbo conversions in the past and can be a nightmare!
But if things were sorted it would be a hoot! - maybe even quicker than a cup....nah cant be, silly me!
chuckle
  Lionel Richie
keep watching chaps!!! coming soon!! :devilish:
BTW to look at the engine is virtually identical
Meggy RS uses the F4R 774
Vel Satis uses F4R 762/763
172/182 uses F4R somenumbericantremember
172 F4R730
Right......the turbo engine uses a different cylinder head casting, different cams, different block with oil drain holes, different crank (thougher) and different pistons.
On a whole you can easily create a hybrid using the 172 engine, but youd need the pistons, drill some return lines, the manifolds and downpipe and the exhaust cam. And if your decided to push it, the turbo crank.
