17inch superleggra question
Car  Nissan 370Z
why do these wheeks rub on some peoples arches and not others, this is baring in mind its set on coilovers.
thanks
^ hes referring to my car fred, in which case u did it and its on dannyboys wheels which are on the wrong offset so yes they will more than likely rub with people in the back
ok thanks, will this mean they will only rub on full lock? if so i would expect that, if not how can you sort this? can u raise car a little bit?
thanks
spacers may help, about 8mm should be about right, but then u may have the problem of rubbing on the arches
