Apart from the four on the calipers are there any more bleed valves on the system such as the master cylinder under the resevoir as I've bled my brakes after changing pads and the car does stop but doesn't feel right
Yeah it was constantly topped up before each wheel was done and rechecked during the bleed. Just noticed that there was a bleed valve on a master cylinder in this months car mechanic - think it was in the Q&A part. thats why the query.
I dont think there is on the Clio, the bleed process in the manual doesnt mention one. It says to do it in a certain order starting from the right rear.
Did you change the pads/discs at the same time?? As they can take a while to bed in.
