182 centre Cap removal tool
Car  Clio Sport 182 2006
Hi! im new on the site, wanted to ask what tool to use to remove the center cap wheel of my clio sport 182 2006.
Regards,
​Niko
I use an alan key that fits in the hole. Put the short end of the alan key in the hole, make the long end stick straight out and pull. when re-fitting, make sure you line up the special indent bit correctly else it wont go on properly.
In the boot should be a leather bag that the scissor jack of death is kept in. Inside should be a bit of polystyrene that the jack fits in, and also kept in a slot in the polystyrene should be a bit of wire that's designed to be the perfect shape for wheel cap removal.
I only discovered it after swearing at a screwdriver the first time :(.
Thanks, that sounds great, will try it tomorrow!
i saw on youtube mostly are using alan key for an Audi, seems it will do the job.
i looked on the same location but there was nothing, :( guess the person i bought it from lost it already.
​Thanks anyway!
