182 cruise control - how to check
Car  RS Clio 182
There are LOADS of posts here on the cruise control in 182 and lots of possible suggestions.
Rather than trying every one, is there a process we can follow to locate the fault?
For example:
1. Push the cruise switch to up. The green light should come on the dash.
If so - does that mean the cruise switch works?​
2. Push the brake pedal and the brake lights should come on.
Does that mean the brake sensor switch works?​
If that's not enough - what else do you need to do to check the brake pedal switch?​
Are there similarly easy checks for other common causes: clutch switch, ABS ring ... ??
Matt
