182 Exhaust Shield bolt.
Car  Titanium 182 FF
Hi all,
i have a Ktec racing 182 Exhaust on the clio and i have noticed a massive rattle. it turns out it is the right hand side (as you look under the car) of the exhaust shield under the boot that is flapping. do you know the size of the bolt that needs to go in there?
many thanks.
Jordan.
The heat shield rots around the nuts that hold it up. You need to undo the nut and get a big washer under the nut to hold the heat shield up again.
Thanks,
the issue i have is the bolt is missing all together. i believe it may have been removed when i had my exhaust change. i know i can go back to the garage but i wondered if anyone knew the size of the bolt ie M6 so i can just replace it myself.
many thanks in advance.
ok, looking at the picture it looks like the its a nut that is missing - ill check properly later at lunch
thanks again guys.
thanks again guys.
It could be the nut, or it could be that the heatshield has worn through the old bolt (usually the case) so there is a hole (the size of the washer) showing. You use the current bolts, but a bigger washer. I did it on mine a couple of months ago now.
