182 handbrake cable
Car  ///M135i
One of my handbrake cables has snapped at the rear caliper is it one cable down the middle of the car from the handbrake then a cable to each caliper off that?
Theres a cable from the actual handbrake lever to the equaliser plate and then two cables from the plate to the each of calipers. Cables will set you back about £65-70 for the pair from Renault and from what I've just seen under mine it looks like a right c**t of a job lol.
Easy job. Just remove the centre heat shield. Slacken off the equaliser. Remove the broken one, replace. Tighten up. Bish Bash Bosh!!!
Should be...except when you only have a s**t jack, it's raining and you're in a bad mood lol.
