182 high idle , throttle pedal ?
Car  wanting a trophy
hi guys and gals , my first post here , ive got a problem on my recently bought 182
the revs seam to stick at around 3000 rpm , but as soon as i lift the accelerator pedal it idles normal
i did do a search and can figure out its a fly by wire
can you replace the pedal or is it a sensor of some sort on the pedal its self , if so were from please
i would apreciate any help please :)
thanks a lot
jeff
i have got a old 172 on a cable and my car revs to about 2000 rpm on idle i got to put my foot under the accelerater pedal to make it go back to idle speed i got the same problem but only when the car is warm i put a new cable on it and taken the throtle body off and clean it which did make a differents for a week then it back to how it is. i'm going to get a new throtle body if it keeps doing it to me
just take it off and clean it thats what i did a friend and a ph2 with the same throtle body as u he took it off cleaned it worked for a bit
Could be the pedal or could be a sticking throttle body - might be worthwhile cleaning it.
just use wd40 its a oil and a good cleaner spray lots on it best to take it off look for a second hand pedal
